September 17, 2019, 06:49 |
inlet velocity setting
ofri
im trying to simulate an air flow throgh a certain pipe, and i need the inlet velocity to varry in time according to the following function: v=1.384*sin(4pi*t-pi/2)+1.384 i tried to insert an expression to boundry condition->inlet->velocity magnitude->expression but im not sure how to write the correct syntax, plus if this is the way to do it. please help |
September 20, 2019, 16:53 |
Hannes Kröger
Rep Power: 18 |
Dear ofri,
you might have a look at the "uniformFixedValue"-BC ("timeVaryingUniformFixedValue" in older OF versions). Among other options, it can take a table of values vs. time and interpolates the current value in between. Regards, Hannes
silentdynamics GmbH - http://silentdynamics.de open source CAE software solutions & support |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Setting angle of inlet velocity. | kareemm2 | OpenFOAM Pre-Processing | 7 | April 15, 2016 05:22 |
Setting a inlet velocity profile with table(x,y,z,time) | Ronan Reve | STAR-CCM+ | 2 | March 24, 2014 14:27 |
Setting pressure and velocity in inlet | Asghari | FLUENT | 5 | September 22, 2006 13:23 |
UDF paraboloid velocity inlet | Ronak Shah | FLUENT | 0 | June 4, 2003 09:44 |
