Home > Forums > FLUENT
Flow accorss in-line tube banks.
Old   February 15, 2016, 07:50
Default Flow accorss in-line tube banks.
Fadi hajj
Fadih is on a distinguished road
Hello guys,
I am doing a simulation for flow over in-line tube banks in ansys-fluent to compare with experimental.
I am facing a problem with heat transfer specifically, I have set a heat flux q=1511 w/m^2, and Tin=300k however minimal heat transfer occurs and the only change in temperature occurs on the tubes surface only which is very odd. I am using periodic boundaries in the y and z directions and velocity inlet for x-direction and pressure outlet.
the set-up is exactly the same as in the experiments, and the mesh is of high quality done using size functions to certain edges to get the cell-shape required.
I think fluent set-up has something missing which is causing no heat transfer.
I have attached pictures of the mesh and temperature contour.
does anyone have any idea how I can resolve this?
Thank you,
Fadi.
Fadih is offline   Reply With Quote
Thread Tools
Trackbacks are On
Problem with Gmsh nishant_hull Open Source Meshers: Gmsh, Netgen, CGNS, ... 23 August 5, 2015 02:09
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 11 April 22, 2014 12:32
2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 12:37
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
