February 29, 2016, 23:02 |
Heat Transfer between two fluids
Ali
Rep Power: 16 |
I would like to simulate heat transfer between Hydraulic Oil (static at 50degC) and air (static at 15degC). Both the fluids contained inside a cylinder. I want to see velocity vectors like in natural convection and temperature variations in both fluids? How can I setup simulation to run in Ansys Fluent? How to give temperature to different fluids (Oil and air)? Will it be a multi phase or single phase heat transfer simulation? I attached a figure for illustration purpose.
Best Regards Ali |
March 1, 2016, 20:06 |
Edoardo
Rep Power: 11 |
To initialize the temperature the way you need it, I would look the UDF DEFINE_INIT for custom initialization.
Heat transfer coefficient - what is waht | Stan | FLUENT | 28 | December 29, 2021 16:29 |
Natural heat transfer in He tank with a heated rod inside | cltormar | CFX | 3 | January 16, 2015 17:59 |
Porous domain:Interfacial area density and heat transfer coefficient | l.te | CFX | 2 | May 17, 2014 23:45 |
radiation heat transfer | GeHa | FLUENT | 1 | September 5, 2012 14:56 |
Help with mass transfer in heat and water vapor exchanger | mullenc525 | CFX | 7 | January 25, 2011 23:26 |
