March 2, 2016, 08:24 |
Wind turbine analysis procedure
Héctor Lodoso
Rep Power: 10 |
Hello.
I am completely new at this forum so first let me thank you all for your posts and all they have helped me just reading. My question is: how do they obtain the torque and rotation speed for each wind velocity at the inlet in a horizontal axis wind turbine? (to obtain power output) Is my first time doing this kind of job and I am alone in my company with this. So I read, I have more or less extracted they tend to separate it into 2 different stages: first, they obtain the torque in a set of different steady states shots, and then, using a 6dof transient case is possible to get the rotation speed when all is stabilized. Is this it, or am I completely wrong? I would appreciate very much some light over this topic. |
March 3, 2016, 06:43 |
numan
Rep Power: 11 |
You have to define rotational speed by yourself. If you are using FLUENT, you define it under "cell zone conditions - select the rotating frame - frame motin tick - write rotational speed = rad/s"
After you simulate it, you should calculate the torque from: results - forces - moments - select rotational direction (enter 1) and compute. Hope it helps |
March 3, 2016, 11:58 |
Héctor Lodoso
Rep Power: 10 |
Thank you, but not.
I would like to know the roadmap to follow for the whole process, the steps companies usually do, and not the technical issues related with Fluent. Do you have this info? |
6dof, fluent, power output, wind turbine |
Display Modes | |
Analysis of horizontal axis wind turbine | Aneeq raheem | Main CFD Forum | 0 | January 25, 2016 10:26 |
error due to interface in a moving mesh/moving frame analysis of wind turbine | swordofangel | FLUENT | 0 | November 23, 2015 12:39 |
Analysis of Wind turbine blade ( 3D aerofoil) by Ansys 12 | rsskarthikeyan | FLUENT | 5 | October 13, 2012 22:29 |
CFX Analysis of a wind turbine | Bournegenius | CFX | 16 | August 20, 2012 19:16 |
Usage of Star-CD in analysis of Wind Turbine | Manabendra M. De | Siemens | 5 | January 6, 2007 23:42 |
