How to obtain radial force distribution graph from FLUENT?
2 Attachment(s)
Hi guys,
I simulated a wind turbine blade (NREL Phase VI) in FLUENT. I need to draw the dimensionless radial force distribution along the blade (as in the attached picture). I know that I need to obtain radial force distribution along the blade first. How do I obtain it? Do I need to add a surface or a line along the Y axis (see attached Fluid Domain) in ANSYS Results? If yes, in which side of blade should it be (there are two sides)? Thank you |
no one? :(
I still couldn't make it, anyone can help?
