Defining transient export parameters
1 Attachment(s)
I am trying to export the data from my model to excel so I can plot as I wish, against each other etc.. I have been stuck on this problem for a while, having had a search around to find the solution I found this page: http://aerojet.engr.ucdavis.edu/flue...ug/node135.htm for which there is a command to export the transient data. Here is my depiction of what the webpage is explaining to me: file/export/ txt data [ list-of-surfaces input interior-symmetry mid onesixty output surface_body twenty ()] [ yes|no] [ list-of-scalars velocity magnitude static temperature liquid fraction q] where: input interior-symmetry mid onesixty output surface_body twenty are my surfaces and where: velocity magnitude static temperature liquid fraction are the parameters of which I want to export. The "txt" indicates I want a .txt file and the file name is data. I have received the following message when trying to run the command: > file/export/ txt invalid command [txt] data [ list-of-surfaces input interior-symmetry mid onesixty output surface_body twenty ()] [ yes|no] [ list-of-scalars velocity magnitude static temperature liquid fraction q] > Also, how do I define the save location for this file? I really need this sorting so I can start to process my results :confused: Kind regards. Kez |
