March 11, 2016, 07:28 |
Temperature Limited Problem
tuna
Rep Power: 10 |
Hi everyone,
I have a problem about "Temperature Limited Problem". BC's of geometry are inlet=308 K and surface temperature of wall is 293 K. But some point temperature is nearly 2437K to 5000K. How can I solve this Problem ? Anyone can help me ? I tried lots of methods. For example I increased mesh elements. 2000000 is enough but increased 4000000 mesh elements and I changed convergence criteria and changed solution methods but I can not find anything. Outlet BC is pressure outlet and default of program of specification method under Momentum title gives intensity and viscosity but my solution model is k-e therefore I changed intensity/viscosity to k-e but this method did not help me. Anyone can help me ? (Note: inlet and outlet hydraulic diameter of my geometry is not same.) Thanks for helps. Best wishes |
March 11, 2016, 16:06 |
Rep Power: 18 |
What is the geometry and where is this peak temperature found? Perhaps include a temperature contour plot.
What are the initial conditions and is the flow steady or transient? |
March 12, 2016, 07:53 |
tuna
Rep Power: 10 |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
Problem in modified pisoFoam with temperature equation + thermophysical model | Matt_B | OpenFOAM Programming & Development | 17 | November 7, 2019 09:23 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
the problem that gradually change of temperature contour in coal gasification | bluenail | FLUENT | 0 | November 10, 2014 02:41 |
Problem when adding temperature to interFoam | houkensjtu | OpenFOAM | 4 | November 5, 2012 02:35 |
