Vertical Axis Wind Turbine
1 Attachment(s)
Hello CFD mates,
I m working on VAWT.I tried all the settings and tricks,after this i m posting my problem here. I m facing following problem :confused: 1)-ve moment coefficient 2)-ve torque with very low value(-0.04 N-m) 3) max pressure on blade is only 30 Pa Settings used in Fluent SST Model BCS used: inlet left-5 m/s inlet right 5m/s outlet left- 0 pa outlet left- 0 pa Fluid MRF-10 rad/s blade-Wall Reference values-5 m/s wind velocty,Swept Area as Area,Rotor Radius as Length i hope to get help from expert one in this field here....I m really thank you so much in advance. |
