The problem of streamlines!!!
Like Tree3Likes
  • 1 Post By Far
  • 1 Post By Far
  • 1 Post By Far
Old   March 19, 2016, 09:49
Default The problem of streamlines!!!
Aja
aja1345 is on a distinguished road
I am simulating a turbine
Please see streamlines around blade in following figures.
Mesh is structure and mesh (between the domains) is conformal and i also used this simulation but problem doesn't solved. How to solve this problem?
I am grateful that guide me.
Best.
Aja
aja1345 is offline   Reply With Quote
Old   March 19, 2016, 11:37
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
this is likely due to rotating and stationary domain.
Far is offline   Reply With Quote
Old   March 19, 2016, 11:43
Aja
There is between rotating and stationary domain. Is there any problem in that?
Old   March 19, 2016, 11:44
Far
Sijal
Originally Posted by aja1345 View Post
There is massive gradient between rotating and stationary domain. Is there any problem in that?
what sort of gradient? It would be much helpful if you can support text with pics....
aja1345 likes this.
Old   March 19, 2016, 12:04
Aja
I am simulating a axial-flow air turbine, namely, Wells turbine. solution is steady state.
This turbine have 8 blades((360/8)=45 deg=angle between blades). Due to the circumferential symmetry, only one eight of the annulus has been computed, imposing periodic boundary conditions in the tangential direction. In my model, the computational domain has been restricted in the axial direction to four chord lengths upstream and eight chord lengths downstream of the blade. Blades are symmetry(Naca00XX).
Computational domain is as follow:
According the following figures, My means about gradient is velocity gradien
Old   March 19, 2016, 12:39
Aja
I want to obtain streamlines as follows (This pic is in a published paper).
Old   March 19, 2016, 22:19
Far
Sijal
take it to CFD post. It is problem of displaying data in two different zones i.e. stationary and rotating.
Right now Fluent is showing data in rotating reference frame...
aja1345 likes this.
Old   March 19, 2016, 22:54
Aja
Thanks for your answer.
My language English is not very good.
What is your exact meaning of "take it to CFD post."? Can you explain more about CFD post?
Old   March 20, 2016, 05:02
Far
Sijal
CFD Post is post processing software by ANSYS. It has more options than Fluent for post processing ...
aja1345 likes this.
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
