[Sponsors] | |||||
Rafau
Rep Power: 14 ![]() |
Hello everyone!
I have gone through many threads, but I have not found clear solution -.- Could you describe me step by step what should i do to compile udf's in fluent (not just adding udfs, but setting compiler Visual C++). Should I change sth in udf.bat file etc.? Ansys 14.5 Windows 7, 64bit Best Regards Rafal |
Rep Power: 27 ![]() |
UDFs for Fluent are written in c. Not in c++. Although historically related, these are different languages, so they use different compilers.
Rafau
I know it is in C ;-) I just mentioned for i.e. the compiler Visual C++.
I do not know how to attach a complier to fluent. |
Ah excuse me, I assumed that "visual c++" could compile c++, I see I am wrong.
If I google for "how to setup compiler for fluent", I get many explanations. Which one did you try? |
ami
Rep Power: 11 ![]() |
To comiple your UDF, you should go to Define=>User defined=> Fonctions=> Compiled =>Add (select your UDF from Sources files)=> Click on "Build"=> Click on "Load". I hope it can help you |
| Tags |
| visual c++. compiler. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
| problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 20:12 |
| The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
| Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 10:28 |
| What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 12:55 |
