Modelling phase change materials in a container |
November 29, 2015, 16:43 |
Kieron
Rep Power: 11 |
I am modelling phase change materials in a container, the container consists of three regions, cold, pcm and hot. The heat from the hot side will melt the pcm and release the stored heat from the pcm to the cold region. Therefore simulating the heat flux from hot to cold with the use of the pcm as a storage unit.
I have used "fill cavity" to model the regions The problem: I am not quite sure how to exactly model the problem I am not sure how to correctly setup the regions so fluent understand which regions contain which fluids, and how to setup the monitors for heat flux. I have attempted the problem before asking, however I dont feel I am setting this up correctly at all. The container is shown, any help would be appreciated for modelling and setting up. |
December 3, 2015, 09:56 |
Kieron
Rep Power: 11 |
bump, still need help with this :/
March 24, 2016, 09:26 |
wan asyraf wan man
Rep Power: 10 |
i am facing the same problem now, have you solve it? if yes, do you mind to share it. thanks
which Model to be used for phase change? | dinesh | FLUENT | 0 | July 10, 2013 05:07 |
Solid/liquid phase change | fabian_roesler | OpenFOAM | 10 | December 24, 2012 06:37 |
Solid/liquid phase change using large viscosity | gregor.vidmar153 | OpenFOAM Running, Solving & CFD | 3 | June 10, 2010 06:31 |
Modelling Phase Change using software.... | ting | Main CFD Forum | 0 | November 21, 2003 00:38 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
