[Sponsors] | |||||
oyeniran oluwatosin
Rep Power: 12 ![]() |
Hi everyone. I got this error message while loading my mesh in fluent.
'The default algorithm used to compute the wall distance required by the turbulence models might produce wrong results in these cells. Please inspect the wall distance by displaying the contours of the 'Cell Wall Distance' at the boundaries. If you observe any irregularities we recommend the use of an alternative algorithm to correct the wall distance. Please select /solve/initialize/repair-wall-distance using the text user interface to switch to the alternative algorithm'. I didn't how to go about solving d problem. Help will be appreciated. Thanks |
Lucky
Rep Power: 68 ![]() ![]() ![]() |
This isn't a problem, it's a warning. This warning is usually displayed when high aspect ratio cells are detected.
High aspect ratio cells are sometimes intentional, like when you have prism layers near the wall, it's very easy to end up with high aspect ratio cells, which will then cause this warning to show up. Wide and flat cells that result in high aspect ratios are okay, but narrow and tall cells are not because the nearest wall may be an adjacent wall (a different wall than the intended wall) which will mess up the distance in the y+ calculation. If you know what you're doing with your mesh, then you can ignore the warning. There's no way to make it go away except to remove the high aspect ratio cells. I forget what the threshold is. |
oyeniran oluwatosin
Alright. A million thanks
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Connecting Fluent benefits and Injection Molding Software | Jim87 | FLUENT | 1 | August 6, 2023 17:06 |
| CFX vs. FLUENT | turbo | CFX | 4 | April 13, 2021 09:08 |
| Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
| heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 07:22 |
| Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 17:48 |
