Gas Liquid Interaction
Old   March 27, 2016, 13:48
Default Gas Liquid Interaction
Karim
Einzo is on a distinguished road
Hello, i'm actually working on a project where i study the feasablity of creating flow in a LPG pipe using natural gas & i want to simulate this with fluent.
So i wanted to know if it was feasable with fluent & if so, is it hard to do for a beginner like me.
Einzo is offline   Reply With Quote
Old   March 28, 2016, 16:01
Lucky
I have no idea what is going on here. What are you trying to model?
Old   March 29, 2016, 06:03
Karim
The black pipe in the image is full of LPG in a static state (no flow) under a pressure of 20bars (300psi) & i want to simulate what happens if we inject natural gas under a pressure of 40bars(600psi) as shown in the image, to see the behaviour of both fluids & see if there will be natural gas dessolved in LPG under the effect of the high pressures.
Basically i want to see if i will be able to push the LPG using the natural gas.
It is frequently done in the oil & gas industry using a pig to separate the fluids from each other, i want to simulate what happens if there is direct contact between the fluids, as the use of pig is impossible in some situations.
Old   March 29, 2016, 10:30
Lucky
Well the answer is, of course you can. Because of continuity. You don't need any fancy thermodynamics/fluid mechanics to determine that, just kinematics.
You'll need to do a multiphase simulation for liquid and gas phases. You'll also need to enable the species solver if you want to look into transport of NG into LPG. This part of the simulation is somewhat easy to do.
The problem with these types of simulations where you have a suddenly imposed boundary condition is, in order to do it with a high degree of accuracy you need an extremely fine grid to resolve the moving front (the gas|liquid interface as it passes through the domain).
Finally, depending on what physical phenomena you are trying to capture at the gas|liquid interface, you might run into some trouble. Surface tension effects are handled with the multiphase options in Fluent, but if you have anything complicated going on there, you might not be able to do it in Fluent.
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
error message cuteapathy CFX 14 March 20, 2012 07:45
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
