[Sponsors] | |||||
Pratik Dhoot
Rep Power: 11 ![]() |
Hello everybody,
I am trying to use UDF for defining turbulence viscosity at a cell as a function of its distance from the wall. I used syntax real x[ND_ND]; C_CENTROID(x,c,t) float d1 = x[0]; to find the x coordinate of every cell in the loop but I get a parse error in the float term. I tried to fix it but I am still struggling. If anyone can help with this, please comment. Thanks, Pratik. |
Rep Power: 19 ![]() |
Fluent UDFs follow the ANSI C standard and variables must be declared at the start of a code block. You've called the C_CENTROID macro and then declared the variable d1. Move this declaration further up, for example:
real x[ND_ND]; float d1 = x[0]; C_CENTROID(x,c,t); |
Pratik Dhoot
Thanks. That was very much useful. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| A Problem of Fluent Interpreted UDF: parse error | knight | Fluent UDF and Scheme Programming | 25 | August 16, 2018 11:26 |
| Parse error interpreting UDF | mrwts | Fluent UDF and Scheme Programming | 2 | September 14, 2015 17:45 |
| Parse error in UDF, URGENT HELP NEEDED!!! | Boris Kloser | FLUENT | 2 | December 12, 2009 04:16 |
| parse error with interpreting UDF | ivanbuz | Fluent UDF and Scheme Programming | 2 | August 13, 2009 19:29 |
| udf parse error | brusly | FLUENT | 0 | February 4, 2007 23:15 |
