The Boundary condition i specified has changed after computation
I'm simulating a Heat exchanger in fluent, i specified boundary condition: mass flow inlet to a fluid with temperature 633K. After iterations the result shows inlet condition to be 603K.
I am using Standard k-epsilon model |
are you sure your boundary conditions -> reference values are also set to your inlet conditions? |
How do i do that?
workbench -> setup -> setup -> reference values
Is there some way it could be done in fluent, i found the reference value in reports, I have two mass flow rate boundary conditions. But there only one can be mentioned. What to do for 2 BCond
