Low Re flow past cylinders in tandem
Old   April 5, 2016, 02:48
Default Low Re flow past cylinders in tandem
Sagar
ksgr is on a distinguished road
Hello all
I am trying to simulate a low Re (Re=100) flow past two cylinders in tandem and I am unable to get vortex shedding which is quite obvious and also reported in literature. When I tried ANSYS Mesh unstructured mesh I was able to get proper results, but when I tried to make a structured mesh with ICEM CFD, I am unable to reproduce proper results. I must say that I am a newbie in ICEM and I have a hunch that my meshing is not proper. So I am attaching the image of my mesh. Kidnly suggest how to go about it.
Regards
ksgr is offline   Reply With Quote
Old   April 5, 2016, 09:16
Far
Sijal
Originally Posted by ksgr View Post
Hello all
Regards
with this mesh you cannot get any results, let alone vortex shedding
Create ogrid around both circles and run the solution.
Old   April 5, 2016, 09:29
Sagar
Thanks Far.
I knew mesh was the culprit. However, I am not able to figure out how to create O grid meshing around 2 circles. I was able to do it successfully for a single circle. With 2 circles, when I try to split block around small circle, it intercepts with the larger circle. Kindly suggest any tutorials where I can learn about blocking for these kind of geometries.
Regards
Old   April 5, 2016, 13:52
Far
Sijal
which cylinder is upstream? smaller or larger?
Old   April 5, 2016, 14:18
Sagar
Smaller cylinder is upstream and the gap between them is 1.2 times the diameter of the bigger cylinder.
Old   April 5, 2016, 17:00
Sagar
In the mean time I tried creating two separate O grid blocks around 2 circles and it looks like this. I'm pretty sure it is not correct. Could you kindly suggest what changes I could make?
Old   April 10, 2016, 17:59
Sagar
Could you please suggest how to make a blocking in this case? I'm not able to figure out perfect blocking strategy so far. Any help would be much appreciated.
FLUENT LES Simulation of flow past a cube NGH FLUENT 6 November 13, 2012 23:45
About compressible flow at low mach hit Main CFD Forum 2 October 26, 2009 21:21
low speed compressible flow lily CFX 2 November 16, 2005 05:15
low speed compressible two phase flow?? cat CFX 0 November 15, 2005 07:59
beginning - Flow past a square cylinders Odenir de Almeida Main CFD Forum 4 February 10, 1999 09:38
