error while importing mesh to FLUENT from ICEM
1 Attachment(s)
I created mesh in ICEM by using blocking. then MESH is converted in to Unstructured mesh and imported to FLUENT.
During Mesh Check, I found : left-handed faces detected on zone 20: 65694 right-handed, 84 left-handed. left-handed faces detected on zone 23: 3574 right-handed, 36 left-handed Info: Used modified centroid in 52 cell(s) to prevent left-handed faces. It is recommended that you try to fix the left-handed faces WARNING: The mesh contains high aspect ratio quadrilateral, hexahedral, or polyhedral cells. The default algorithm used to compute the wall distance required by the turbulence models might produce wrong results in these cells. Please inspect the wall distance by displaying the contours of the 'Cell Wall Distance' at the boundaries. If you observe any irregularities we recommend the use of an alternative algorithm to correct the wall distance. Please select /solve/initialize/repair-wall-distance using the text user interface to switch to the alternative algorithm. How can I solve it. Why are these warnings coming during Mesh check. Can anyone help me . Thank in advance |
