March 6, 2008, 13:24 |
udf wall distance segmentation violation
Dear all,
I would like to get the function C_WALL_DISTANCE(c,t) to work for an UDF that I use. If the flag "enhanced wall treatment" is selected everything works fine, otherwise a segmentation violation error occurs. Does anybody know a way to go around this problem? Best regards, Gento |
April 15, 2016, 15:59 |
Pratik Dhoot
Rep Power: 10 |
I have the same problem. If you have found a way out yet, you can let me know. Thanks. |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
specified shear at wall - temperature gradient - UDF - access violation error | senD | Fluent UDF and Scheme Programming | 9 | September 18, 2014 07:29 |
UDF segmentation violation error | be89 | Fluent UDF and Scheme Programming | 1 | December 21, 2012 03:07 |
udf segmentation violation when hooked | jjchristophe | Fluent UDF and Scheme Programming | 9 | June 25, 2012 05:46 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
