October 22, 2010, 09:59 |
use batch mode to run an unsteady case
Rep Power: 15 |
Hi !
I would like to use batch mode to run an unsteady case. I understand how it work for a steady case reading the example ( ; Read case file rc fluent.cas ; Initialize the solution /solve/initialize/initialize-flow ; Calculate 200 iterations it 200 ; Write data file wd example200.dat ; Exit FLUENT exit) But for a unsteady case, you cant use "it" and I've looked in the manual and I didn't find the command. Could somebody help please. Note that I would like to run a case where I have 1800 time steps of 10s each with 50 iterations per time step. Thank you very much ! |
October 24, 2010, 14:26 |
Grzegorz Kondora
Rep Power: 15 |
dti n_step n_iter_per_step, for example:
dti 10000 20 |
October 24, 2010, 15:50 |
Rep Power: 15 |
Do I need to indicate a time step ? How ? |
October 24, 2010, 16:05 |
Grzegorz Kondora
Rep Power: 15 |
Do you mean time step size??? The value of time step size can be set in GUI before running in batch mode. You can set time step size via journal as well, just search.
October 25, 2010, 04:33 |
Rep Power: 15 |
I tried the dti command. My computer write :
> invalid command [dti] I don't understand. Anyways thank you for your help. |
October 25, 2010, 04:42 |
Grzegorz Kondora
Rep Power: 15 |
/solve/dti 1000 20
September 16, 2014, 17:26 |
Thank you. It was time saving
March 29, 2019, 22:44 |
Rep Power: 7 |
Hi, I want to use batch mode for the 3D steady case and I am using .jou file as
rc fluent.cas rd fluent.dat solve/set/ri 10 solve/set/iterations 15000 file/write-case-data file-name.cas exit yes but it is not working. can anyone tell me what is the problem? thanks |
April 1, 2019, 10:18 |
#9 |
Lucky
Rep Power: 65 |
This is a problem but not the problem:
solve/set/iterations is not a valid command the correct command is solve/set/number-of-iterations That setting is just a setting. It doesn't do anything. To actually iterate you need to do: solve/iterate 15000 or it 15000 |
April 4, 2019, 08:18 |
#10 |
Rep Power: 7 |
Thank you! I used ' it ' command and it worked.
batch unsteady runcase |
Running macros in parallel in batch mode | nomad | STAR-CCM+ | 13 | February 22, 2013 08:30 |
Running fluent with udf in batch mode | zonexo | Fluent UDF and Scheme Programming | 2 | March 10, 2012 07:50 |
Flux update during an MPI run between decomposed case parts? | scott | OpenFOAM | 0 | July 21, 2010 20:47 |
Prosurf in batch mode | Dhruv | Siemens | 1 | September 19, 2005 18:02 |
run star-applications in batch mode | thomas | Siemens | 6 | November 14, 2004 09:19 |
