Is this the correct setup? Non-Newtonian fluent Problem
Old   May 4, 2016, 01:57
Post Is this the correct setup? Non-Newtonian fluent Problem
DanielH is on a distinguished road
Problem: You have a thickened (non-Newtonian) fluid passing through a water bottle top, where you know the initial pressure is vacuum (0kpa) and the a lab results gives you a flow rate of say 0.000779kg/s and the static pressure drop was seen as 10kPa with laminar flow. (assuming model and mesh is done and fluent set up is only needed)
General:Pressure based, Absolute and steady
Models: Only viscous (Laminar)
Material: fluid is almost like water, copy water poperties and change viscosity to non-Newtonian power law and add parameters
Cell Zone conditions: Change it to you non-Newtonian fluid
Boundary conditions:Set operation conditions to 0pa
Define inlet as Mass-flow-inlet at 0.000779kg/s
Define Outlet and Outflow
Define interior and walls
Solution methods: Use Simple
Solution controls: Change nothing
Solution Initialization: Hybrid with 10 steps, initialize
Run Calculation: run with 250 iterations and what for convergence
Wala take results???? Is this correct or have I missed something
DanielH is offline   Reply With Quote
Old   May 9, 2016, 00:59
Bump, Please help :/
Old   May 18, 2016, 01:05
Also like to add I am getting a shear rate of crazy amount from a range of 20-10,000 1/s
Old   May 31, 2016, 11:07
Bhargav Bharathan
bhargavbharathan is on a distinguished road
Your set up looks fine. I suggest going to monitors and setting the residuals to atleast 1e-5 for better precision.
As for the shear rate, where did you arrive at numbers as big as 20-10,000 1/s? I generally give small numbers of the order 0.01.
-BB
bhargavbharathan is offline   Reply With Quote
Old   June 16, 2016, 20:16
I meant strain rate... Sorry somehow I was must have misread it... but for my Wall Shear stress it is around 0 (possible very very small) to 43pa.. Btw thank you for the reply, what I am trying to find is Strain and Shear rate range to determine if the simulation is viable though I am not sure if I am using the right methods to do so.. I am just using Contours and using the range they give me.
Old   August 31, 2016, 15:43
Default Yielded and unyielded region in viscoplastic flluid
naushad is on a distinguished road
Hey Everyone!
I'm unable to plot yielded and unyielded region for a flow of viscoplastic fluid
in a square enclosure.
Help me I'm stuck.
Thanks
naushad is offline   Reply With Quote
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 04:09
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
Setup Cell Error in Fluent on Workbench tolu FLUENT 1 September 12, 2013 13:28
[ICEM] [FLUENT] 2D Geometry problem when exporting to Fluent - Unwanted walls MikeTichondrius ANSYS Meshing & Geometry 1 February 9, 2011 13:31
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 28, 2010 23:32
