May 4, 2016, 15:56 |
Change phase phenomena
imane
Hello everyone,
I am beginner in fluent v15, and I want to simulate the temperature change as a function of time in the phase change materials "PCM" and the heat thermal fluid "HTF" and the PCM fusion Front. Regarding the geometry I chose to work with two coaxial tubes: the inner tube contains the heat thermal fluid and the outer tube contains the PCM for meshing I appointed the input, output and symmetry area of HTF and PCM. Also the entry, exit and the symmetry of the wall between the PCM and the HTF The set up steps followed are: General ==> Type: based pressure, velocity formulation: absolute, time: transient Model ==> volume of fluid with 2 stages in number eulerian, energy, melting and solidification Materials ==> PCM characteristics: density, solidius and liquidus temperature , thermal conductivity, pure solvent latent heat and thermal expansion coefficient for the HTF I chose to work with liquid water Phases ==> Primary phase pcm, Secondary phase HTF Cell Condition box ==> Wall (phase mixture, Type: Solid) HTF (phase mixture type: Fluid, Fluid porosity: 1) PCM (phase mixture type: Fluid, Fluid porosity: 1) NB: I want to determine the porosity of the fluid depending on the temperature f (T) - f(T) = 0 if T < Ts - f(T) = 1 if T > Tm - 0 < f(T) = (T -Ts) / (Tm - Ts ) < 1 if Ts < T < Tm but I don't know how to do it with new input parameter Boundary Conditions ==> in this stage I entered the HTF input velocity and the inlet and outlet temperatures of the HTF, PCM and WALL but I find myself stuck facing problem with the symmetry area of HTF and PCM. and other boundary conditions appear as: wall-htf-wall, wall-htf-shadow-wall, wall-pcm, wall-pcm-wall, wall-pcm shadow-wall, wall-wall but I do not know what to choose for thermal conditions: temperature convection heat flow or or ... and if for example I chose the heat flux how can I calculate the heat generation rate and the heat flux. I will be very grateful for your help and thank you in advance. Best regards; |
help for simulation phase change | sudni | COMSOL | 0 | January 17, 2014 02:47 |
homogeneous free surface flow with phase change. | Niru | CFX | 13 | December 26, 2013 10:27 |
Pressure Outlet for phase change simulation | dinesh | FLUENT | 0 | November 21, 2013 23:50 |
Solid/liquid phase change | fabian_roesler | OpenFOAM | 10 | December 24, 2012 06:37 |
Solid Phase change material | qiulan | Siemens | 0 | June 5, 2006 15:30 |
