Error in parallel computing- multiphase flow+UDF
I have run a multiphase flow problem in parallel computing. The case is to simulate a printhead nozzle. There is a piston inside the nozzle which vibrates in 100Hz. Piston force is 15N. UDF is applied to describe piston’s action. When I run the case , FLUENT shows the warning message and stop computing.
I have run another multiphase flow problem without UDF in parallel computing. It’s working. So I’m sure the MPI has installed correctly. I guess there are something wrong in UDF code. Can anyone help me to fix it? Warning message: Info: 6DOF: can't compute angular acceleration. Check moments/products of inertia. Updating mesh at time level N... done. 999999 (..\src\mpsystem.c@1172): mpt_read: failed: errno = 10054 999999: mpt_read: error: read failed trying to read 51172 bytes: No such file or directory Error: eval: unbound variable MPI Application rank 0 exited before MPI_Finalize() with status 1 Symbol Error encountered in critical code section The fl process could not be started. UDF code: #include "udf.h" DEFINE_SDOF_PROPERTIES(moving_piston, prop, dt, time, dtime) { #if !RP_HOST real y; #endif #if !RP_NODE prop[SDOF_MASS] = 0.5; prop[SDOF_IXX] = 0; prop[SDOF_IYY] = 0; prop[SDOF_IZZ] = 0; prop[SDOF_ZERO_TRANS_X] = TRUE; prop[SDOF_ZERO_TRANS_Z] = TRUE; prop[SDOF_ZERO_ROT_X] = TRUE; prop[SDOF_ZERO_ROT_Y] = TRUE; prop[SDOF_ZERO_ROT_Z] = TRUE; #endif #if PARALLEL host_to_node_real_4(prop[SDOF_MASS],prop[SDOF_IXX],prop[SDOF_IYY],prop[SDOF_IZZ]); host_to_node_real_5(prop[SDOF_ZERO_TRANS_X],prop[SDOF_ZERO_TRANS_Z],prop[SDOF_ZERO_ROT_X],prop[SDOF_ZERO_ROT_Y],prop[SDOF_ZERO_ROT_Z]); #endif #if !RP_HOST y=CURRENT_TIME; if(y<=0.005) { prop[SDOF_LOAD_F_Y]=-15; } else { prop[SDOF_LOAD_F_Y]=15; } printf ("\n2d_test_box: Updated 6DOF properties"); #endif } |
Inter-Process Data Transfer macros such as node_to_host should never be inside a compiler directive
For example; #if RP_NODE YOUR CODE; #endif node_to_host |
