stabilize detached bow shock in transonic flow
Old   May 8, 2016, 05:03
Default stabilize detached bow shock in transonic flow
BigJoe is on a distinguished road
I'm trying to capture a stabilized detached bow shock in transonic flow(M=0.8). The choking Mach here is 0.84 based on area ratio. But what I found is that the bow shock appears at the beginning of the simulation(500 iterations) and then it moves upstream, changes BC at inlet which results in lower Mach than what I set based on total pressure inlet and static pressure outlet.
Any help on it. I even decreased M=0.7 at inlet and it still has this problem....Should i use gradient adaptaton for mesh or change solution method(QUICK, 3rd order)?
I'm using k-w SST in order to capture vortex shedding behind. Y+ is 0.7 more or less.
BigJoe is offline   Reply With Quote
Old   May 8, 2016, 19:08
Any one have any advice on it? Much Appreciate!
Supersonic flow over an airfoil. FLUENT Lift don't match up with Shock Expansion Tech enriccasas FLUENT 1 August 21, 2013 07:43
Different flow patterns in CFX and Fluent avi@lpsc FLUENT 4 April 8, 2012 07:12
Reverse Flow Problem. (Hull with a Bulbous Bow )Towing Tank simulation. Nyarla Siemens 2 March 13, 2012 20:04
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 3, 1999 00:18
Exp. data for transonic flow J. Held Main CFD Forum 4 April 1, 1999 23:21
