[Sponsors] | |||||
Use of Reynolds Stress Model (7 equations) in micro-combustion |
Pradip
Rep Power: 12 ![]() |
I am trying to simulate premixed combustion in micro-combustor (18mm X 8mm X 3mm). When I use k-epsilon model then combustion is not happening, but when I try it with Reynolds Stress Model(RSM) then it is giving results. I have read that RSM is used in circulating flow. Is it okay to use RSM in micro-combustion? Anyone is here who can guide me? Thank you in advance
Lucky
Rep Power: 68 ![]() ![]() ![]() |
The RSM model is generally much more powerful than any of the two equation models. In general, there aren't any situations where the two equation models are valid, that they RSM model can't do better. Just be careful because RSM is not well-benchmarked across a wide range of flow scenarios.
But I don't think RSM model is part of the problem or solution for no combustion. I think you just need to check your combustion model. The only thing that changed is the turbulence model, the turbulence-chemistry model is more or less the same and the combustion model is the same, RSM does not affect these. |
Pradip
@LuckyTran Thank you for your suggestions. I will go ahead with this model and check results with experimental values.
| Tags |
| micro-combustion, reynolds stress models |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Simulation of Axisymmetric Free Jet using LRR Reynolds Stress Model | skyinventorbt | OpenFOAM | 1 | January 2, 2022 18:42 |
| New implemented algebraic Reynolds stress model | volker | OpenFOAM | 13 | October 21, 2013 01:01 |
| reynolds stress in k-e model | ayapan | FLUENT | 3 | December 23, 2005 14:49 |
| Reynolds Stress Model in Fluent Vs CFX | Tim | FLUENT | 0 | December 6, 2005 23:03 |
| Reynolds Stress Model | Cui | CFX | 1 | July 17, 2003 13:39 |
