May 24, 2016, 04:01 |
Mesh deformation in ANSYS Fluent DDPM
Rupesh Verma
Rep Power: 12 |
Dear Friends,
I want to ask one fundamental question. My question is mesh deformation/ mesh dynamic is possible or not in ANSYS Fluent DDPM simulation [for multiphase flow: liquid/gas and solid particle]. I want to deform the mesh in ANSYS Fluent DDPM. Thankyou |
May 31, 2016, 10:56 |
Bhargav Bharathan
Rep Power: 10 |
I have done both of them separately. Try it out and let us know if they work together.
Message me to discuss if necessary. Good luck. -BB |
June 1, 2016, 01:05 |
#3 | |
Rupesh Verma
Rep Power: 12 |
Thankyou |
June 1, 2016, 10:16 |
#4 | |
Bhargav Bharathan
Rep Power: 10 |
What I meant was I have done DDPM simulations and mesh deformation separately although, I have never done a simulation with both of them in it. For mesh deformation I use profiles and for DDPM I use UDFs. -BB |
June 2, 2016, 03:45 |
Rupesh Verma
Rep Power: 12 |
You applied mesh deformation in case of multiphase or in one phase [E-E or E-L]. Also, for the same problem you have applied mesh deformation and DDPM separately or your, both problems were different?
June 2, 2016, 10:06 |
#6 | |
Bhargav Bharathan
Rep Power: 10 |
24.1.2.3. Limitations on Using the Discrete Phase Model with Other ANSYS Fluent Models - Surface injections will be moved with the mesh when a sliding mesh or a moving or deforming mesh is being used, however only those surfaces associated with a boundary will be recalculated. Injections from cut plane surfaces will not be moved with the mesh and will be deleted when remeshing occurs. -BB Last edited by bhargavbharathan; June 2, 2016 at 10:09. Reason: spelling errors |
June 2, 2016, 10:38 |
#7 | |
Rupesh Verma
Rep Power: 12 |
Dear Friend, i am simply want to know, how did you deform the mesh for your case
Thanks Quote:
June 2, 2016, 10:42 |
Bhargav Bharathan
Rep Power: 10 |
June 2, 2016, 10:44 |
Rupesh Verma
Rep Power: 12 |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 03:34 |
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? | RPjack | ANSYS Meshing & Geometry | 2 | August 27, 2015 09:33 |
[Other] Pointwise Mesh into Fluent - Error: "Divergence detected in AMG solver: ads-0." | kyles.sverige | ANSYS Meshing & Geometry | 3 | January 27, 2015 12:28 |
[ICEM] Missing face error from FLUENT even after repairing mesh + other questions | unknown159 | ANSYS Meshing & Geometry | 0 | July 5, 2013 20:18 |
Mesh data exchange from ansys to fluent | Yong-Ju Hong | FLUENT | 0 | January 28, 2001 21:42 |
