Ansys 17
I have ran 5 very similar simulations in Ansys 17 fluent.
4 worked well and I have obtained the results. One however has been a pain from the start. Ranging from Meshing problems to floating points etc. I sorted all the above and it happily ran 10,000 iterations. All 5 displayed 600-630 N pressure as expected. In post processing 4 happily showed the pressure contours and the streamlines I set up. Apart from one. I verified all parameters and setups were identical. Yet, the last one will only show one single solid flat colour in CONTOURS. I tried many adaptions but still no changes. So, I re-run the 10000 iterations. Again, when selecting contours (150 or even 10 contours) only one is displayed, in one single blue colour. I do not understand what is wrong. Any advice ? |
