How to make an Animation with overlayed scene?
Old   May 6, 2016, 03:52
Default How to make an Animation with overlayed scene?
SJSW is on a distinguished road
Hi~
I am running a case with DPM(discrete phase model).
I tried to make animation that showed particle track and velocity contour at the same window.
I had tried "overlay" function in Display→Scene→Scene Compositon→overlay(checked).
My method runned as follows:
1. Create a solution animation in window ...for example, number 2.
2. Go to "Display→Scene" and check "overlay".
3. Create another solution animation. Be SURE using the same window.
4. Initialize and run "Calculate".
However, it didn't work.
Can anyone tell me how to make an Animation with overlayed scene?
Maybe in CFD-post?
Thank you!
SJSW is offline   Reply With Quote
Old   June 1, 2016, 05:52
Luke
aerospace84 is on a distinguished road
Hi have you solved? i'm going to ask to the customer support for the overlays scene..
aerospace84 is offline   Reply With Quote
Old   June 1, 2016, 05:58
No, I didn't solve this.
What I can do now is to save .dat files, read them into FLUENT, and then overlay the scenes manually. It's a time-consuming work.
Would you please share the method if you got any help from the customer support?
Thank you!
Old   June 6, 2016, 09:15
Luke
Hi!i've asked.
Two ways, 1° to save with execute command every picture and then put them inside a sw like movie maker...
2° the other way is to save a .dat every n° timestep and then to rebuild the scene with cfd post...with the command Key Frame Animation
Old   June 6, 2016, 09:25
Luke
just another things: the overlay doesn't work with the solution animation
Old   June 6, 2016, 10:01
Thanks for your information.
Such a bad news...I hope CFD-post will be improved in next version...or somebody tell me other ways.
Old   June 6, 2016, 14:02
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Did you try Tecplot?
Far is offline   Reply With Quote
Old   June 6, 2016, 20:32
It seems OK.
However, DPM particle track could not be shown in Tecplot?
I couldn't find in FLUENT how to export the particle track to Tecplot. @@
On compiling examples of CGNS nba1942 Main CFD Forum 4 October 9, 2015 03:27
[swak4Foam] some errors in compiling groovyBC in OF220 immortality OpenFOAM Community Contributions 10 April 1, 2013 03:46
how to make animation in star ccm *NM* raziftech Siemens 3 October 17, 2007 02:35
make an animation plots from the data colopolo Main CFD Forum 4 September 30, 2003 10:45
[Q]How to make MPEGs with CFD datas??? Bum-Seok Hyun Main CFD Forum 4 February 16, 2000 18:59
