June 9, 2016, 10:56 |
BC for vent silencer Simulation
a_budiono
Dear All,
I'm doing simulation vent silencer located downstream of control valve which has maximum flow rate limit. I set the BC: Pressure inlet and Pressure Outlet which activate the Mass flow target according to max. flow rate of control valve. However, the result shows that the flow rate is always higher than target flow rate setting which is in reality is not possible. Could someone please help me how to limit the flow rate with Pressure Outlet BC or with other BCs? Thanks for your help. Regards, Budiono |
Waterbell Simulation | o.b.m | Fluent Multiphase | 1 | November 5, 2015 05:55 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 03:16 |
mass flow rate issue in supersonic nozzle simulation | xkang | FLUENT | 0 | July 31, 2014 16:06 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 10:44 |
Continuous vs interrupted simulation | sega | OpenFOAM Running, Solving & CFD | 4 | November 3, 2008 14:29 |
