June 14, 2016, 06:00
custom monitor in batch mode
Sylvain
Hello everyone,
I need to use Fluent with a Cluster and I have a problem.
I set most of things with the GUI like on the attached picture, save the case and sent it to the cluster.
My journal is the smallest as possible, i just want the cluster to run the calculation:
/file/read-case /Home/Users/smagny/WORK/s56/case56.cas
/solve/initialize/hyb-initialization
y
/solve/iterate
100
/file/write-data Results56
y
exit
y
At the end, my custom monitoring keep saing my heat transfer is 0 according to the job's report:
> /solve/iterate
Number of iterations [1] 100
iter continuity x-velocity y-velocity energy k epsilon surf-mon-1 time/iter
1 1.0000e+00 1.3139e-03 2.4630e-04 5.6539e-08 5.1766e-02 1.4336e-01 0.0000e+00 0:00:25 99
2 6.8116e-01 4.0080e-04 1.2350e-04 5.7139e-08 2.6396e-02 5.2076e-02 0.0000e+00 0:00:25 98
3 4.1853e-01 1.6948e-04 7.8726e-05 5.7231e-08 1.8633e-02 3.4462e-02 0.0000e+00 0:00:25 97
4 2.7320e-01 1.1086e-04 6.6634e-05 5.7402e-08 1.5855e-02 2.9381e-02 0.0000e+00 0:00:24 96
5 2.0693e-01 9.3033e-05 6.3601e-05 5.7505e-08 1.4370e-02 2.7935e-02 0.0000e+00 0:00:24 95
6 1.5978e-01 8.2547e-05 5.6736e-05 5.7603e-08 1.3430e-02 2.6963e-02 0.0000e+00 0:00:24 94
7 1.2815e-01 7.4764e-05 4.8425e-05 5.7693e-08 1.2721e-02 2.7257e-02 0.0000e+00 0:00:24 93
8 1.0251e-01 7.0542e-05 4.5457e-05 5.7777e-08 1.2139e-02 2.7700e-02 0.0000e+00 0:00:23 92
9 8.4295e-02 6.6981e-05 4.1016e-05 5.7858e-08 1.1639e-02 2.7825e-02 0.0000e+00 0:00:23 91
10 7.0577e-02 6.4054e-05 3.9833e-05 5.7938e-08 1.1173e-02 2.7392e-02 0.0000e+00 0:00:23 90
11 5.9943e-02 6.3388e-05 4.0171e-05 5.8017e-08 1.0778e-02 2.6478e-02 0.0000e+00 0:00:23 89
12 5.2100e-02 6.1943e-05 3.9396e-05 5.8092e-08 1.0403e-02 2.4992e-02 0.0000e+00 0:00:22 88
13 4.5636e-02 6.1112e-05 3.8772e-05 5.8165e-08 1.0065e-02 2.3377e-02 0.0000e+00 0:00:22 87
14 4.0975e-02 5.9758e-05 3.8124e-05 5.8236e-08 9.7418e-03 2.1630e-02 0.0000e+00 0:00:22 86
15 3.7244e-02 5.8666e-05 3.8385e-05 5.8305e-08 9.4245e-03 1.9875e-02 0.0000e+00 0:00:22 85
16 3.4869e-02 5.7605e-05 3.7855e-05 5.8371e-08 9.1227e-03 1.8205e-02 0.0000e+00 0:00:22 84
17 3.2901e-02 5.6602e-05 3.7025e-05 5.8436e-08 8.8329e-03 1.6701e-02 0.0000e+00 0:00:21 83
18 3.1747e-02 5.5023e-05 3.5561e-05 5.8500e-08 8.5564e-03 1.5441e-02 0.0000e+00 0:00:21 82
19 3.0733e-02 5.3557e-05 3.4660e-05 5.8561e-08 8.3038e-03 1.4453e-02 0.0000e+00 0:00:21 81
20 3.0404e-02 5.2322e-05 3.3944e-05 5.8622e-08 8.0756e-03 1.3917e-02 0.0000e+00 0:00:21 80
21 3.0400e-02 5.1136e-05 3.3329e-05 5.8681e-08 7.8676e-03 1.3687e-02 0.0000e+00 0:00:20 79
22 3.0112e-02 4.9922e-05 3.2344e-05 5.8739e-08 7.6667e-03 1.3633e-02 0.0000e+00 0:00:20 78
Of course, my "Surf-mon-1.out" says also the same thing:
"Convergence history of Surface Heat Transfer Coef. on heattransfer-zone_de_contact-src (in SI units)"
"Iteration" "Area-Weighted Average Surface Heat Transfer Coef."
1 0.
2 0.
3 0.
4 0.
5 0.
6 0.
7 0.
8 0.
9 0.
10 0.
11 0.
98 0.
99 0.
100 0.
Should I write something more in my journal? Could anyone help me please, thank you
