Water solid jet simulated by DPM particles !!!! |
July 16, 2010, 04:22 |
Rep Power: 17 |
Hi there!
I've been simulating water jet (diameter of 2 mm) impinging upon flat wall (100centigrades). Firstly, I did it via VOF model and results are OK especially heat fluxes agreed well with measured data. Now I have switched the same case to DPM approach and I try to solve it with Lagrange particles (droplets). I know that I am breaking fluent limitation on an allowed volume fraction in a cell (10%), But I want to test it anyway. I have already succesfully modeled a cold flow without heat transfer. When I tried to simulate heat transfer with WallJet BC, I've got 70times lower values of HTC than I should have got. Than I tried also switched to Wall Film BC with solving species transport, but here I've got negative values of HTC instead of possitive ones. I've also written my own DPM-LAW for inert particles, but it has helped only a little. Any suggestions ??? Thanks in advance! Bohis |
June 17, 2016, 08:32 |
#2 | |
James
Rep Power: 12 |
Hi Bohis, Have you solved your problem? I cannot solve the heat transfer between a solid body (1000K) and water particles using DPM. It seems that particles are not cooling the body, it is only the air (continuous phase) that reduces temperature of the body. I am considering heat transfer meshing the solid and using Couple BC at the interface. Let me know your thoughts if you have successfully solved your problem. Thanks in advance! T |
DPM - do the particles affect the liquid? | Nikhil Dani | FLUENT | 0 | January 1, 2009 11:58 |
Dispersed Solid particles in carrier gas (DPM) | Frederik | FLUENT | 1 | June 3, 2008 05:13 |
DPM - Melting of Solid particles | Devin | FLUENT | 0 | September 12, 2002 11:42 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
