Segmentation Fault with Get_Domain?
Hi all,
I'm having a bit of trouble with my UDF and can't seem to find anything to solve it. My code is simple, but I hope that will only make it easier for someone to spot my mistake. I'm basically just trying to create a pressure profile. I'm also using DEFINE_ON_DEMAND instead of DEFINE_PROFILE because my goal is to eventually use data from other surfaces in this code (which, by my understanding, will require those domains and threads as well). #include <udf.h> DEFINE_ON_DEMAND(pressure_profile_TEST) { Domain *d = Get_Domain(1); Thread *t = Lookup_Thread(d, 5); int i; real x[ND_ND]; real y; face_t f; begin_f_loop(f, t) { F_CENTROID(x, f, t); y = x[1]; F_PROFILE(f, t, i) = 10; } end_f_loop(f, t); } Running this yields the error: Error: received a fatal signal (Segmentation fault). Error Object: #f Thanks for reading! Please let me know if you have any suggestions. |
