Continous flow over the domain - boundary conditions |
June 25, 2016, 13:31 |
Rafał Pilaczyński
Hello everyone!
I have a simulation to make about flow over the domain. It is simple 2D rectangle domain with dimensions of 320x240 milimeters with 1 inlet and 1 outlet. I know what is the desired mass flow rate at the outlet and since it should be the continous flow it would be the same as the mass flow rate at the inlet. When I am giving boundary conditions like this:
Is this the right way to handle this problem? Maybe - since I know what velocity should be at the inlet it is better to define inlet as Velocity-inlet? I know what mean gauge pressure should be inside of the domain (around 2000 Pa) |
boundary conditions, simple case |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 08:16 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Appropriate Boundary conditions for jet flow in open domain | shrutidhara.123 | FLUENT | 0 | August 5, 2014 10:27 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
