need help with fsi of blood flow through artery
I am doing fluid structure interaction of blood flow through artery in the case of asymmetrical fusiform aneurysm (abdominal aortic). Im using ansys workbench 15. i have udf for velocity and pressure written in a c file. My analysis is showing error for pressure values above 50 pascal while i need to run the coupling analysis for 10000-17000 pascal range.
do we need to give a pressure constant value along with udf velocity as inlet boundary condition in setup of fluid flow(fluent). Please share any information regarding this. Thank you |
Hey,
I think you should give udf velocity profile as an inlet with constant/fixed pressure. What error are you getting? Can you show your udf ? What boundary condition are you using for outlet ? |
the following is my inlet and outlet boundary conditions as functions in the same c program. after i interpret this c program in the ansys workbench, i assign velocity udf as inlet boundary and pressure 101325 Pa. then i assign pressure udf as outlet boundary. thats how i tried to do. I'm using i7 computer with 8gb ram and 3.4GHz.
Thanks for the reply :) #include "udf.h" DEFINE_PROFILE(inlet_velocity,th,i) { face_t f; begin_f_loop(f,th) double t=(CURRENT_TIME*2-floor(CURRENT_TIME*2))/2; { if(t<=0.0586) {F_PROFILE(f,th,i)=0.0064;} else if((t>0.0586)&&(t<=0.234)) {F_PROFILE(f,th,i)=(((2239*t*t*t)-(814.3*t*t)+(73.01*t)-1.4099)/100);} else if((t>0.234)&&(t<=0.3049)) {F_PROFILE(f,th,i)=(((5327.9*t*t)-(2433.3*t)+277.94)/100);} else if((t>0.3049)&&(t<=0.5202)) {F_PROFILE(f,th,i)=(((-5947.8*t*t*t)+(7368.3*t*t)-(3146.8*t)+474.48)/100);} else if((t>0.5202)&&(t<=0.6836)) {F_PROFILE(f,th,i)=(((-48372*t*t*t*t)+(120715*t*t*t)-(112868*t*t)+(46881*t)-7301.2)/100);} else if((t>0.6836)&&(t<=0.8705)) {F_PROFILE(f,th,i)=(((3252.7*t*t*t)-(7381*t*t)+(5543.3*t)-1377.3)/100);} else if((t>0.8703)&&(t<0.8892)) {F_PROFILE(f,th,i)=(((-368.44*t*t)+(644.33*t)-281.05)/100);} else if((t>0.8892)&&(t<=1)) {F_PROFILE(f,th,i)=0.005714;} } end_f_loop(f,th); } DEFINE_PROFILE(outlet_pressure,th,i) { face_t f; begin_f_loop(f,th) double t=(CURRENT_TIME*2-floor(CURRENT_TIME*2))/2; { if(t<=0.1979) {F_PROFILE(f,th,i)=(101325+((27943*t*t*t*t)-(11166*t*t*t)+(1236.2*t*t)-(77.561*t)+80.944)*133.3223);} else if((t>0.1979)&&(t<=0.3756)) {F_PROFILE(f,th,i)=(101325+((-27358*t*t*t)+(24083*t*t)-(6556.3*t)+636.68)*133.3223);} else if((t>0.3756)&&(t<=0.5729)) {F_PROFILE(f,th,i)=(101325+((12473*t*t*t)-(17029*t*t)+(7485.9*t)-946.66)*133.3223);} else if((t>0.5729)&&(t<=1)) {F_PROFILE(f,th,i)=(((-223.03*t*t*t)+(620.47*t*t)-(592.34*t)+275.83)*133.3223);} } end_f_loop(f,th); } |
Blood flow in artery
Shilpa
I would really appreciate if you can tell me what solution you came up with for this problem? Or if anyone else knows? Thank you. |
