[DPM/DDPM]How to employ UDF only for total flow rate of a injection?
Dear all,
My simulation is transient, and I have tried DEFINE_DPM_INJECTION_INIT and 'loop(p,I->p_init)' inside for a simple constant-flow-rate case. However, the tracked particle number didn't increase with time. In this situation, I start to think about writing an UDF which only modifies the total flow rate of a injection. I believed I could do it since we have a dropdown right beside the total-flow-rate blank. Unfortunately, I failed to find the way to do it although I thought I've well read through the UDF guide.. Does anyone has some good ideas? |
It seems I made a mistake when employing DEFINE_DPM_INJECTION_INIT. I'm now attempting with it. Back soon for any news! |
Sorry I made a mistake in my codes. The good news is that you can freely use the macro to set the injection flow rate as a function as you like -- it perfectly works with the transient DPM simulation. |
ask for help
DEFINE_DPM_INJECTION_INIT(fuel,I) { Particle *pt; real time = RP_Get_Real("flow-time"); real m1=0.012667, m2=0.014057; loop(p,I->p_init) { PP_FLOW_RATE(p) = (fuel_m1+(fuel_m2-fuel_m1)*time/0.6)/12; } } When I intepret it, here's error:"reference not implemented", when I compile it, erro:"not for parallel“ Now I wonder whether my code is right but not for parallel, or I got something wrong? Can you show me the way you solve it ? I'd appreciate your help! |
the only part which could be a problem for parallel consideration is this line:
real time = RP_Get_Real("flow-time"); Code:
real time = CURRENT_TIME; |
