Home > Forums > FLUENT
Wrong result of NACA0012 for 10 angle of attack
Old   June 27, 2016, 05:56
Default Wrong result of NACA0012 for 10 angle of attack
Jacky
dragonercfd is on a distinguished road
Hi ,everyone,
I am newer for CFD,doing the simulation of NACA0012 for 10 deg angle of attack. But I always do not get correct result. All the procedure are followed by the Youtube. The following are the parameters of setting.
1 Density: 1.225kg/s
2 Viscosity Coefficient : 1.8375E-05 kg/(m*s)
3 Character Length: 1.0m
4 Velocity: 90m/s
5 Reynold number: 6.0E+06
6 Y+: 1.0
7 Wall adjacent distance: 4e-3mm
8 Total grid number: 180,000
9 Spalart-Allmaras model and K-Omega-SST turbulent model
10 Boundary conditions: Velocity inlet/Outflow/Symmetry/Wall
I must use velocity inlet boundary in order to add some velocity fluctuation on it. So I can not use the compressible solver. The iteration step has been reached up to 145000, but the flow field also is divergence and the result is not unstable. I am afraid that I have set the fault parameters or conditions.
Attached file is my case and Cp and Cf distributions along the lower wall. The result is wrong clearly. If you are available, please help me check it. Thanks very much.
My email is iamdragoner@gmail.com
Best Wishes
Jacky
dragonercfd is offline   Reply With Quote
Old   August 13, 2016, 04:45
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
hi
Were you able to solve your problem?
Far is offline   Reply With Quote
Thread Tools
Trackbacks are On
udf error srihari FLUENT 1 October 31, 2016 15:18
how to find the angle of attack in the wind turbine blade lin-lynn STAR-CCM+ 3 March 17, 2015 05:34
[CFX,ICEM] Simulation of wing / airfoil profile - pyramid elements, angle of attack Jonas_mm ANSYS 2 November 4, 2011 04:26
Problem with airflow over naca0012 and angle o f attack Lucas OpenFOAM Running, Solving & CFD 2 February 18, 2011 14:13
a serious problem on a case with attack angle anne CFX 0 November 18, 2008 06:28
