May 6, 2013, 13:30 |
NIST real gas model can not converge
I am doing a simulation recently. With heat exchange and flow.
If I define the gas material parameters as constant such as density, it can be converged. First I simulate the flow case. Then I do the heat exchange. It is ok. But as the temperature change range is from 40K to 300K. So I change to NIST real gas model. Then it can not converge. |
May 6, 2013, 14:01 |
error message
Error: REFPROP_error (-51) from function: trnprp (viscosity)
[TRNPRP warning -51] one or more inputs to the thermal conductivity and viscosity correlations are out of range; will use ECS model; temperature > 1.5 x upper limit, T = 5000.0 K, Tmax = 1500.0 K |
March 24, 2014, 00:09 |
nist real gas midel R134a
arun km
Rep Power: 14 |
sir
i am doing a simulation of an ejector (vapor jet refrigeration system) with NIST real gas model.I am getting the same result that you have got earlier.Please share the remedy if you solved this problem recently. Thanks in advance |
June 29, 2016, 03:44 |
Malte Semmel
Has anyone found a solution on this topic already?
I am facing the same problem and am desperate for help. Kind regards, Malte |
error: uninitialized local variable 't' used | MASOUD | Fluent UDF and Scheme Programming | 5 | October 17, 2016 04:24 |
Using real gas models in Fluent | neville | FLUENT | 1 | June 5, 2012 05:54 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
UDF error - FLUENT received fatal signal (ACCESS_VIOLATION) | Eliasjal | Fluent UDF and Scheme Programming | 1 | March 7, 2012 11:11 |
about the real gas in Numeca | redboy | Fidelity CFD | 2 | March 4, 2003 07:57 |
