June 29, 2016, 15:43 |
Transient Species Transport
Rep Power: 9 |
Hello everyone.
I am a college student trying to model the flow of acid through a porous rock sample. I am currently in the process of simply modeling the species transport through a cylinder before adding in the complex mechanisms. Below I've included my geometry and mesh: My Fluent setup is as follows:
July 5, 2016, 12:02 |
Rep Power: 9 |
I know there are a lot of questions asked on this forum, but any insight would be very helpful.
July 6, 2016, 07:46 |
Rep Power: 10 |
The issue of not being able to turn off the energy equation is most probably caused by the fact that something in your setup needs the result of the energy equation as an input. For example, check your materials if there are some material properties that depend on temperature. Then Fluent won't let you turn off the energy equation.
July 6, 2016, 15:50 |
#4 | |
Rep Power: 9 |
July 6, 2016, 17:09 |
Rep Power: 10 |
Depends on your system. You can set the density as constant if you know it beforehand. Or volume-weighted-mixing-law should do as well. You need to choose the definition that satisfies your physics.
July 8, 2016, 10:48 |
Rep Power: 9 |
February 25, 2018, 04:32 |
#7 | |
Rep Power: 8 |
Inlet 1: fluid A Inlet 2: fluid B (Bulk species) Output results (mass fraction of A) at the outlet: Steady case: 0.5-0.6 Transient case: 0 |
reversed flow, species transport, transient |
Surface instabilities with 2-phase species transport | richard222 | Fluent Multiphase | 0 | May 4, 2016 04:06 |
Implement species transport equation | Tobi | OpenFOAM Programming & Development | 0 | June 2, 2012 13:26 |
analyze results of species transport | sunflower | FLUENT | 0 | May 11, 2012 04:49 |
Species Transport with Multiphase flow in FBR | venkat | FLUENT | 1 | July 23, 2008 23:53 |
Can Fluent handle species transport in multi-phase | Roger | FLUENT | 1 | January 30, 2003 19:12 |
