Is it possible to simulate angular acceleration of compressor(or turbine) in Fluent?
Old   November 21, 2017, 01:23
Question Is it possible to simulate angular acceleration of compressor(or turbine) in Fluent?
Zeng
Soll is on a distinguished road
I am now working on simulating compressor dynamic with variable rotational speed. I plan to do it in a MRF system and set the rotational speed vary with time or time step. However I cannot find where to input this variable.
I read the documents and it shows the momentum equation in MRF has included the angular acceleration term, which implies its ability to deal with this problem?
Does anyone know if this is possible in Fluent? Using UDF or TUI or any other ways.
Soll is offline   Reply With Quote
angular acceleration, fluid flow
6DOF: can't compute angular acceleration laurentb FLUENT 7 July 26, 2019 12:54
Help required to simulate droplet flow in FLUENT sunilgknair CFD Freelancers 2 May 31, 2016 07:30
How to simulate a hull in Fluent using VOF dmaz FLUENT 11 August 4, 2015 14:54
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 10:54
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 02:00
