July 4, 2016, 07:14 |
Dimensionless Number
Rep Power: 9 |
Hi
In the article generally was worked dimensionless number. When I work fluent. I change the fluid properties to obtaining the these dimensionless number. My question is related to nusselt. Is there any difference dimensionless Average Nusselt Number (in the article) and average nusselt number that I was calculated in the ansys fluent. How can I compare these result. Thank you in advance. Last edited by typhoon1010; July 4, 2016 at 18:52. |
July 5, 2016, 03:13 |
Lucky
Rep Power: 65 |
What article are you referring to?
Be careful, because in Fluent the reference properties for the Reynolds number and Nusselt number are explicitly declared in the reference values pane. Even if you change the actual material properties (like density, conductivity, etc) in the materials pane, you still need to specify the reference values. The reason is that the density in Reynolds number and conductivity in Nusselt number are somewhat arbitrary reference properties, that need not correspond to the real material properties. So the reference values are not automatically computed, they are user specified. Also note the reference temperature that is buried in the heat transfer coefficient. |
July 6, 2016, 12:01 |
#3 | |
Rep Power: 9 |
Thank you in advance. |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
[ImmersedBoundary] Immersed Boundary Method in OpenFOAM-3.1-ext | miladrakhsha | OpenFOAM Community Contributions | 106 | July 3, 2023 10:26 |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 18:32 |
ERROR #001100279 has occurred in subroutine ErrAction. | smnaryal | CFX | 11 | December 20, 2017 16:32 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
