Liquid level VOF model
Hello everyone,
I am using the VOF to model a pool and a gas space, with a velocity-inlet boundary condition injecting water at the bottom of the tank. The rest of the boundaries are walls with no-slip. I am using a 2D axisymmetric model (with x-axis set as axis of rotation). Checking the Report>Fluxes>Mass flow rate>Net shows that I am injecting a correct amount of water through the velocity-inlet boundary condition. However, the liquid level in the pool increases at a much slower rate than what it should, based on the injection rate :confused:. What could be the reason for this? I have double checked the density of the fluids, pool dimensions, mass flow rate injected into the pool, and they seem to be correct. Thanks in advance! =) Ignacio |
