July 14, 2016, 00:26 |
Judging convergence
Zeinab
Rep Power: 10 |
Hello everyone,
I have modeled flow past a cylinder with Fluent. I need some advice in terms of judging convergence. The flow is turbulent using the K-w-sst turbulence model. I also changed the "under-relaxation factor" as instructed in user guide: "If unstable or divergent behavior is observed, however, you need to reduce the under-relaxation factors for pressure, momentum, k, and epsilon from their default values to about 0.2, 0.5, 0.5, and 0.5" I don't understand what this convergence history means. (Please see the attached photo). The solution is converged but I'm not sure what the fluctuations imply. I appreciate any comments. Cheers Zeinab |
July 14, 2016, 01:26 |
Amin
Rep Power: 14 |
It seems alright. You're solving a transient fluid flow, in this kind of problems the solver uses the result of the converged iteration in previous time step as a first guess ( what we call initialize in fluent) for the next one. so suddenly the the residuals soar then drop and converge .
convergence, flow past a cylinder, fluent |
Display Modes | |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
In the case of convergence | aja1345 | FLUENT | 1 | July 31, 2015 03:58 |
judging convergence through residuals | MachZero | Main CFD Forum | 7 | December 25, 2012 12:18 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
