[Sponsors] | |||||
NACA Airblade simulation: Steady vs. transient / Outflow vs. Pressure Outlet |
Chris
Rep Power: 11 ![]() |
I want to simulate the flow around a NACA profile for different stagger and incidence angles. Especially the loss coefficients and velocity ratios behind the profile are of interest and will be matched with experimental results I'll obtain in the next weeks. For very small incidence angles I'm getting bad results: With the previous settings of my case I obtain large losses as a result of a flow separation on the full length of my blade. The results of the experimental investigation of my colleagues suggest that these enormous losses won't appear for my configuration too. Cause the residuals and some monitors oscillated I switched to a transient calculation. The residuals haven't got better (maybe a problem of timestep?), but the flow separation is much smaller and fits better in the loss bucket created by the values of higher incidence angles. Cause I'm not sure if the outflow boundary condition is appropriate I repeated the steady simulation with an pressure outlet condition. This led not to better residuals, but the losses are smaller than in my first simulation. Now I'm confused – what would be the right approach? I've attached some velocity plots and the residuals for the first steady simulation with the outflow bc (blending first-to-second-order). Thanks for your help! |
Chris
Residuals for outflow bc (Blending first-to-second-order 0.5 -> 1)
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 18:16 |
| Unsteady pressure differential between inlet and outlet of the pipe for single phase | joshi20h | FLUENT | 0 | September 26, 2012 13:41 |
| Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 14:45 |
| Transient simulation (Problem with massflow and Pressure) | ChristianF | CFX | 4 | August 22, 2011 22:42 |
| stagnation pressure in transient flow simulation | K.S.Ravichandran | Main CFD Forum | 2 | September 5, 2000 01:34 |
