Plot pressure distribution on a section of 3d blade
Old   July 1, 2010, 22:32
Default Plot pressure distribution on a section of 3d blade
Wirot
Dr.been is on a distinguished road
My wind turbine blade has spanwise direction in z ,chordwise in x ,thicknees of airfoil in y. After simulation, I use XY plot -> pressure -> static pressure, choose monitor at z= 30% span (which i has created already with Iso-surface) to show pressure distribution over airfoil at this section.The xy plot show as the attached picture below which is very confuse for me. What should I do? Any one can help me?
So, I really need your valuable guidelines!
Sincerely yours
wirot
Dr.been is offline   Reply With Quote
Old   July 8, 2010, 10:05
Jouke de Baar
jack1980 is on a distinguished road
My guess is that you have now plotted all values on the iso-surface, whereas you are only interested at the values that are actually on the foil surface.
Perhaps you can instead create a clip surface, where you clip the foil surface from, say, 29.9 % to 30.1%. (Or maybe even 30% to 30% although I'm not sure this will work.)
Good luck!
jack1980 is offline   Reply With Quote
Old   July 22, 2016, 05:03
Ramin
rmn_990 is on a distinguished road
Hi
you can do it in 2 ways:
1-opening it in tecplot and using a plane for each section
2-in Cfd Post.you should define a plane--->define a polyline at the intersection of plane and blade---->define a chart with x axis of blade's chord and y axis of pressure or somthing else at the intesection on plane and polyline which makes an airfoil that you want to have pressure chart of it
Best Regards
Ramin
rmn_990 is offline   Reply With Quote
Plot on a curve Monica FLUENT 1 July 11, 2012 00:24
Pressure Rise Error emueller CFX 0 May 5, 2009 11:08
plot pressure distribution on a section of 3D wing ROOZBEH FLUENT 3 April 21, 2008 03:30
Pressure plot by wing slice Matt FLUENT 1 November 26, 2005 20:04
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
