Finite Rate doesnt burn, while Eddy Dissipation does. |
July 24, 2016, 03:58 |
Francesco Ventura
Hello fellow CFD'ers
I have an industrial boiler to simulate, and for my thesis work i have to do it with both ED and FR approaches. The problem is steady state, and there is no other difference between the two cases except the combustion models. I already tried to patch a high temperature and small amounts of products, but nothing happens. The fuel is wood-volatiles, plz send help |
changing a variable (turbulence dissipation rate) formolation | m.beh | Fluent UDF and Scheme Programming | 6 | November 7, 2016 05:53 |
change a variable in dissipation tem of turbulence model | behest | Fluent UDF and Scheme Programming | 0 | March 28, 2014 08:31 |
How to use Eddy Dissipation rate only When using Finite rate/Eddy Dissipation model | Dziyad | FLUENT | 2 | February 19, 2014 17:25 |
Eddy dissipation model | PeterBishop | OpenFOAM Programming & Development | 0 | November 1, 2013 05:59 |
eddy dissipation | Adrian | Main CFD Forum | 0 | March 30, 1999 09:17 |
