UDF Surface to Volume Ratio
Hi All,
Is there a way to implement a UDF to alter the surface-to-volume ratio in space of a porous media? Thank you, GF |
Volume to Surface Ratio
Could you be able to find a way ?
Thanks. |
Surface Area Density
Its fairly simple - you can use DEFINE_PROFILE but only if you want it to change from iteration to iteration. Else, use an expression or a profile file.
