July 26, 2016, 11:11 |
Dynamic Mesh Settings for compressed FSI
I am trying to simulate a lubrication theory problem where a fluid is being compressed between two rubber rotating rollers to the point where the fluid needs to be ~0.1 mm by utilizing FSI coupling. No matter my dynamic mesh setup I have been getting negative mesh volumes. I have tried reducing my time step down to 0.001 and have the following settings for dynamic mesh: Methods: Smoothing-Diffusion, Diffusion Function(boundary-distance), Diffusion Parameter (1) Remeshing: Local Cell, Local Face, Parameters (Use defaults) Dynamic Mesh Zones: Surfaces in contact with rollers: System Coupling with the cell height set as the specified element size from the fluid mesh. All other surfaces: Deforming with zone parameters set based off the bounds from the zone scale info I am relatively new to ANSYS Fluent and this is my first time using FSI coupling. Any help would be greatly appreciated! |
ansys 17.0, dynamic meshing, fsi 2-way coupling, remeshing |
Dynamic mesh using profile | sanjeetlimbu | Fluent Multiphase | 3 | April 19, 2018 09:49 |
FSI Dynamic Mesh Separating? | dcp2387 | FLUENT | 0 | June 20, 2016 17:50 |
Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh | Emanuele88 | FLUENT | 0 | February 9, 2016 11:39 |
Update of the variables after dynamic mesh motion. | gtg258f | OpenFOAM Programming & Development | 9 | January 18, 2014 10:08 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
