October 16, 2016, 10:18 |
#21 |
SELANGOR, MALAYSIA
Rep Power: 9 |
Greetings Sir,
I've some more inquires regarding the rotation axis. Based on my reading, Fluent is using right handed coordinate system , so the rotation will be counter clockwise on specified rotation axis. Thus, based on this, I set my coordinate system to be (0,0,1) with 3008 RPM, as my blade should have normal rotation (counter-clockwise when viewed from the front). I did my analysis, and by observing the streamline animation (on CFD-post), it shows that it rotates clockwise. Then I did another testing, with (0,0,-1), with RPM 3008, the results of streamline animation shows its counter-clockwise. Which is actually correct? The result is much different when its clockwise. Kindly please advice. Thank you in advance. |
Blade Thickness Distribution w/ Blade Distortion | twolfe13 | Main CFD Forum | 1 | May 22, 2014 00:10 |
Compressor Blade Analysis in Ansys CFX | LynchMobster47 | Main CFD Forum | 0 | April 10, 2012 22:43 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
Blade thickness on propeller wash prediction | Lam | Main CFD Forum | 1 | October 28, 2005 02:36 |
Propeller thrust at diff. advance ratio (CFX 5.7) | Zoltan | CFX | 9 | April 27, 2005 08:23 |
