April 9, 2019, 05:10 |
Adjoint solver convergence issue
Alasdair
I'm running a batch file to optimise the flow over a 3d wing using the adjoint solver in fluent, however I cannot get the adjoint solution to converge. I have reduced the number of cells to 2.5 million and attempted to use different stabilization schemes to no avail. In the past I managed to quite easily optimise an aerofoil section, but I cannot get this 3d wing to work. Has anyone used the software for a larger number of cells? If so do you have any advice? Thanks, Alasdair |
May 6, 2019, 11:20 |
adjoint solver
medhat
hello
my question is can i use adjoint solver in case of dynamic mesh |
adjoint solver, adjoint solver fluent, convergence, fluent |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Convergence issue with Fractional Step Method using RK2 method for time integration | mihirmakwana6 | Main CFD Forum | 23 | June 6, 2015 06:58 |
Fluent Adjoint Solver for compressible flow | b.shuvayan | FLUENT | 2 | January 30, 2015 07:27 |
force convergence problems in CFX 6DOF rigid body solver | ajay_ks | CFX | 8 | March 25, 2013 04:02 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
