Display
Old   August 11, 2016, 13:01
Default Display
Mojtaba
mojmar1369 is on a distinguished road
Hello,I have a problem with the "scaled residuals" section of the ANSYS FLUENT,when I run the "calculation" or "iteration" the process continues properly and finally it becomes complete,but it doesn't display the diagram in "scaled residuals" window,also after that you can not see the Contours and etc. .The print screen is in the attachment.What can I do? Please help me as soon as possible,because I'm in a rush,Thanks in advance!
mojmar1369 is offline   Reply With Quote
Old   August 12, 2016, 04:14
Onur Özcan
oozcan is on a distinguished road
First, scaled residuals are not very important and probably you couldnt find it in order to shut your FLUENT software down. As you wanted to open/work FLUENT again, you couldnt see it. But if you want necessarily to see it, you need to look up ''view'' command in FLUENT interface,I am not sure but That is not a hard thing to find.
oozcan is offline   Reply With Quote
Old   August 12, 2016, 06:11
Default Graphical Problem
Mojtaba
Thank you for your advice,did you see the attachment?you know,I can't see the Diagram and when the program iterates,the related diagram doesn't display and I can't see the problem's solving treatment,even after that I can't get my goal,because I want some Contours and diagrams to use them in my thesis!
[Other] paraFoam error scybchenjun OpenFOAM Meshing & Mesh Conversion 0 May 11, 2016 23:25
Scheme Executable Terminating Prematurely ec44 Fluent UDF and Scheme Programming 1 April 6, 2015 03:34
[OpenFOAM] Xlib: extension "GLX" missing on display goldbeard ParaView 5 March 24, 2013 13:12
errors when installing openfoam2.1 on ubuntu12.o4 hewei OpenFOAM Installation 5 May 29, 2012 07:43
free surface display carno Siemens 4 October 7, 2005 01:03
