Boundary Pressure Different Than The Defined Transient Pressure Profile |
August 17, 2016, 12:05 |
Karim Shalash
Rep Power: 14 |
Hello everybody,
I am currently studying a flow in a 90 degrees bent pipe, that is closed at one side (resonator). The flow boundary that I have is a pressure inlet, where I define a transient pressure profile for it (Sinusoidal wave). As a sanity check, I am writing an output surface monitor file at the pressure inlet boundary, yet I am getting a different profile than my input. It is worth mentioning that I am using double precision solver. My profile is having a resolution equal to my time step. Any ideas? Thanks in advance... KS |
August 27, 2016, 04:05 |
Karim Shalash
Rep Power: 14 |
I found the problem...it is the reversed flow through the single inlet/outlet boundary of my domain!
August 28, 2016, 11:23 |
Daniel Riveros
Rep Power: 10 |
So, what did you do? Did you extend your domain?
August 31, 2016, 10:18 |
Karim Shalash
Rep Power: 14 |
No, I did not. I was just puzzled why the monitor at the boundary is not showing the profile I defined, which as I said was due to the reversed flow through the single inlet/outlet boundary of my domain.
Cheers, Karim |
UDF for transient pressure outlet boundary from data array | nathanblank | FLUENT | 1 | June 1, 2015 03:09 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
